Author Topic: Rust on bottom  (Read 3535 times)
Offline Eric Zebe
Rust on bottom
« on: February 04, 2023, 11:44:13 AM »
Hello All:  I have a skillet that is well seasoned except for the outside bottom.  It has a light film of red rust.  Is there a way to treat the bottom in a way that will resist rust and not burn off?
Thanks in advance!
Not all who disagree with wisemen are fools
Re: Rust on bottom
« Reply #1 on: February 04, 2023, 04:01:13 PM »
Eric, I would spray the bottom lightly with White Vinegar, and let it sit for a while .  Wash with soap and water, then repeat until rust is gone, then oil lightly a then put it in the oven for a while.  Likely just flash rust from sitting in a damp spot.....
Re: Rust on bottom
« Reply #2 on: February 04, 2023, 09:35:55 PM »
The process of seasoning a pan involves coating it with oil, and then oxidizing that oil with heat and air. Every time you heat a pan, that seasoning continues to oxidize and burn off. The bottom of any cast iron used for cooking is always the most neglected spot, yet it receives most of the direct heat while cooking. Always check the bottom of any user piece of cast iron; because, the seasoning will both wear (from movement and sliding) and burn off (due to being directly heated). What Cheryl has posted is good advice. Just like any other piece of cookware, cast iron must be maintained. Just check the bottom of your user pieces every so often.
Re: Rust on bottom
« Reply #3 on: February 05, 2023, 05:49:07 AM »
Eric, what type of are you using it on?(gas, electric, glass top)
Offline Eric Zebe
Re: Rust on bottom
« Reply #4 on: March 04, 2023, 08:04:33 PM »
Hello, its used on a gas stove.
