Author Topic: Rushed seasoning process  (Read 9781 times)
Offline Craig Allison
« on: August 22, 2023, 12:41:47 PM »
On a couple of pieces, I followed standard seasoning procedures but as the pan cooled to around 250 or so I repeated the process.
It seems to have worked but I'm just worried that complete cooling is an important part of the process.
What do the experts say to this process?
Re: Rushed seasoning process
« Reply #1 on: August 22, 2023, 07:08:00 PM »
Cooling is not that important. Some people here actually "hot season" their cast iron. That means they are applying a second coat with the piece around 500 degrees F. It is really "restorer's choice" when seasoning iron. It depends on how comfortable (and careful) you are seasoning an already hot pan.
« Reply #2 on: August 22, 2023, 07:51:29 PM »
Craig, No expert here. But if the finish product pleases your eye, do it to it! :thumbsup:
« Reply #3 on: August 23, 2023, 01:00:29 AM »
Craig, I hot season my iron with no problems (except of course the risk of getting burned while applying new seasoning materials).  To do this I preheat the oven, when it reaches 450F I apply the seasoning material, roast for 1 hour, pull out the piece, apply a new round of seasoning material, back in the oven, etc.  The most I have ever done is 5 coats of seasoning in serial fashion.  I let the pan cool only when I turn off the oven after the final coat of the day.
The best advice I received when I joined WAGS was read up on seasoning, pick a method, try it, if it works, continue.  If it doesn't work, ask for help.   :wink: :wink: :wink:
Offline Tom Penkava
« Reply #4 on: August 23, 2023, 08:55:49 AM »
Craig, I use the sleeve from an old shirt folded and tongs to apply Crisco, remove the hot pan from the Weber grill, apply a new coat of Crisco, back into the grill and keep heating to the smoke point again, I usually apply 5 to 7 coats before letting the pan cool down, why lose the heat in the pan between applications when all you are doing is Appling more Crisco to achieve a deeper seasoning.
Be as quick as you can to not lose too much heat from the pan, helps to speed up the process, a good pair of welders gloves comes in handy too.
« Reply #5 on: August 24, 2023, 01:10:23 AM »
I 2nd. Tom on the Weber grill :thumbsup: Keeps everyone "INSIDE" the house happy! :vrolijk_26:
« Reply #6 on: August 27, 2023, 05:10:57 PM »
The menfolk kicked me out of the kitchen MANY years ago to the Weber Grill and the Great Outdoors!   :grin: :grin:
I have heavy duty huge cardboard tray boxes (the kind Carpet Squares come in).  I line with HD Aluminum Foil to plop a skillet in to season!
Only the ones I decide to use.... all others are coated with low heat  (indoors) and Food Grade Mineral Oil.   :wink:
« Reply #7 on: August 28, 2023, 11:50:25 AM »
Cheryl, can you post a photo of your foil-lined cardboard box set up?  I'm having trouble visualizing it.
Back when I was married, I waited until my ex-wife and her sister went on vacation, then I took a few days off from work to have a cast iron seasoning and Grateful Dead marathon.  They would come back from vacation and had no idea what I had done.   :wink:
« Reply #8 on: August 28, 2023, 12:33:58 PM »
Here ya go!  Different sizes... Largest is the Carpet Square Box.
After covering the inside with HD Aluminum Foil, I would then have another square of cardboard to set the pan on!
When the inner square got gunked up, pitch it and replace.
Costco is a good source for large 'flats' also!
« Reply #9 on: August 28, 2023, 06:37:03 PM »
Cheryl that's quite the seasoning set-up you have there!  Mine is quite disorganized by comparison!
I hope that included a few rounds of "Ripple" (pun intended).
« Reply #10 on: August 29, 2023, 01:34:26 AM »
Quote from: Jim Glatthaar on August 28, 2023, 11:50:25 AM
Quote from: Sandy Glenn on August 28, 2023, 6:37:03 PM
... and "A Touch of Gray"
« Reply #11 on: August 29, 2023, 01:45:49 AM »
Cheryl, does the foil lining protect the cardboard from burning or do you have to season at a temperature below the burn point of cardboard (whatever that is)?
« Reply #12 on: August 29, 2023, 07:55:55 AM »
It was more to provide a double layer to protect the resin folding patio table that the box was sitting on!  :smiley:
I have always used High Heat Seasoning... 475 ° to 500°.  (and to help absorb excess oil). I never had any problem with burn thru.
I rarely do traditional seasoning anymore, because there is no way I'm EVER gonna use them all. (and unused, seasoned pans tend to turn color if not used).
So now it is easy, peasy low heat and coat with Food Grade Mineral oil after restoration.  :smiley:
No fumes or smoke either! (225° max temp)....
« Reply #13 on: August 29, 2023, 02:48:22 PM »
Maybe ideas for a future convention: how to season on a Weber grill; which is better gas or charcoal; winter outdoor seasoning of cast iron?  Or maybe a Casting Call article?
« Reply #14 on: August 29, 2023, 07:32:36 PM »
Gas Grill for sure!  :wink:
« Reply #15 on: August 30, 2023, 02:49:59 PM »
Cheryl, with the low heat/mineral oil seasoning, is the pan heated and then oiled?
Curious minds...
« Reply #16 on: August 30, 2023, 03:55:44 PM »
Craig, yes.  I place the item in a large restaurant size aluminum roasting pan, and heat to 225°.  then pull it out of the oven, coated liberally and place back in the oven for 30 + minutes.
Pull it out and wipe down oil from the pan (paper towels), until it 'appears' dry.  :smiley: Then wipe again.
Sop up excess oil in aluminum pan and scrub it well with soap and dry.
All mineral oil soaked paper towels go in trash can.
A word of caution: Food grade mineral oil has a VERY LOW smoke point, and FLASH point, so I don't want any drips into the oven.
The fumes once it smokes or catches fire are noxious to breathe.
It could be applied at a lower temperature, but I have found the above works well for me.
And no color changes over time and if dusty, then a rag with a trace or MO will make it pretty again.
If for some reason I would want to 'use' it, I just fire up the Weber Grill outdoors, place it on the grid and close the lid!
« Last Edit: August 31, 2023, 11:42:07 AM by Cheryl Watson »
« Reply #17 on: August 31, 2023, 09:40:08 AM »
Thank you.
« Reply #18 on: September 01, 2023, 02:06:01 AM »
Craig, this page reinforces what WAGS is all about: telling people how some of us season their iron, what works and what doesn't work, or to forego seasoning and opt to protect the iron.  There are many different ways to season iron so we each find our own special way of doing so.
« Reply #19 on: September 01, 2023, 07:15:37 PM »
I have unused seasoned pans and have never seen any color changes.
What exactly should I be looking for?
