Author Topic: Lye percentage  (Read 3383 times)
Online Craig Allison
Lye percentage
« on: October 01, 2023, 10:37:29 AM »
The ratio I've been using is around 1# of lye to 5 gallons of water.
Works great especially when it's hot outside.
I've read of folks using much higher amounts of lye with good results.
I'm getting ready to start a larger tank for doing larger pieces. Hopefully running it through most of the Kansas winter.
Is the 1 to 5 ratio going to be effective in cold weather or should it be higher?
Re: Lye percentage
« Reply #1 on: October 01, 2023, 03:15:19 PM »
The ratio you are using is not quite what you think. Five gallons of water weighs about 42 pounds. So your ratio is 1:42, not 1:5. Your current concentration in your lye bath is just over 2% (~2.4). Most people here use at least 5% lye, or in your case 2 pounds of lye in 5 gallons of water. So your lye bath has half the strength of my lye bath. There are other people here that use 10% lye solutions, which would be 4 pounds of lye in your 5 gallons of water.
Re: Lye percentage
« Reply #2 on: October 01, 2023, 03:43:02 PM »
OK Thanks. I may have misunderstood what I thought I knew. Info from another site.
Looks like I'll buy some more lye.
Re: Lye percentage
« Reply #3 on: October 02, 2023, 06:19:03 PM »
Craig, I have always mixed my lye baths with 2lbs per 5 gallon.
Now the caveat...
1.  make sure your container can handle the weight of the iron + liquid.   I use BRUTE containers, and have a hanger system to retrieve pieces. (So I never have to reach very far into the solution)
2.  Never ever try to move a Lye Bath that contains solution.
3.  When working with my Lye Baths I wear Chemical Gloves (not dishwashing gloves) AND a Full Face Shield. Protect those eyes! if a large piece I might pull on a Vinyl Apron also!
4.  I keep an 'active' hose at my feet, just incase an emergency rinse is needed.
 :smiley: :smiley:
Re: Lye percentage
« Reply #4 on: October 02, 2023, 10:07:13 PM »
And I assume it's OK to add more lye to the tank that I'm currently using.
As long as I add lye to the water and not the water to the lye.
Re: Lye percentage
« Reply #5 on: October 03, 2023, 01:13:32 AM »
Yes.  Adding more is sometimes necessary. :)
