Author Topic: Nickel (or chrome?) plated BSR #3S  (Read 1052 times)
Offline Spurgeon Hendrick
« on: July 27, 2017, 06:19:13 PM »
Saw this today. Anybody know who played BSR skillets? Maybe a homemade job?
I didn't buy it, but thought it was pretty interesting.
« Last Edit: July 27, 2017, 06:20:15 PM by SpurgeonH »
Re: Nickel (or chrome?) plated BSR #3S
« Reply #1 on: July 28, 2017, 08:26:26 AM »
I would be suspect if that is actually a BSR, the underside of the handle (scoop) and the quality of the casting are rough at least to me.
The + sign and the 3 dots in the scoop are also strange, The dots I have seen on the hammered unknown iron I have seen
« Reply #2 on: July 28, 2017, 02:25:23 PM »
I believe that is a BSR/ASW "S" Series (smaller) No. 3....
However, ASW/BSR did not plate pieces, so I would suspect an aftermarket plating or paint job, which would account for some of the observable defects.
The 'DOTS' on ASW/BSR pieces have been routinely observed inside the handle cutout as seen above, and occasionally on the bottom of skillets with letters and or numbers.  :)
« Reply #3 on: July 28, 2017, 05:55:03 PM »
I wonder if with the smaller skillets if the pattern didn't have multiple skillets on it. And the dots ID'd which skillet on the pattern. The 4 dots would have been the 4th skillet on that Pattern.
Offline Paul Reed
« Reply #4 on: September 03, 2017, 02:49:45 PM »
Is this silver enamel possibly? Seen a lot of enameled BSR from around that era
When justice is done, it is a joy to the righteous but terror to evildoers.
Proverbs 21:15
