Author Topic: Yikes, a homemade spider skillet  (Read 5512 times)
« on: December 04, 2019, 12:53:00 PM »
Here’s one for the cast iron X-file book. It looks like an early Century #8 with legs welded to it. Those are some long legs. Someone must have wanted to cook over a bonfire with that one.
Re: Yikes, a homemade spider skillet
« Reply #1 on: December 04, 2019, 01:36:58 PM »
Just when you think you've seen everything and can no longer be surprised...  ;D
Offline Lee Bowen
« Reply #2 on: December 04, 2019, 03:39:06 PM »
You know you are a redneck when ................. :D
« Reply #3 on: December 04, 2019, 05:13:03 PM »
I am...............
Speechless.........!
Takes quite a bit to render me such..............  :grin: :grin: :grin: :rolleyes: :rolleyes:
« Last Edit: April 19, 2021, 12:19:05 AM by Cheryl Watson »
« Reply #4 on: December 04, 2019, 08:36:00 PM »
As I often say..."Any port in a storm" :shocked: :shocked:  :grin:
« Last Edit: April 19, 2021, 12:19:56 AM by Cheryl Watson »
Offline Tom Reisdorf
« Reply #5 on: December 05, 2019, 10:48:12 AM »
I was taught to cook on the coals from the fire not the blazing fire,  easier to control the heat. They must have not gotten that memo.
« Reply #6 on: December 08, 2019, 10:43:46 PM »
That is certainly different.
Offline Lee Bowen
« Reply #7 on: December 09, 2019, 11:02:52 AM »
Upon closer scrutiny, the weld almost resembles J-B Weld, or some other two-part heat resistant epoxy, with it's smooth exterior, absence of weld marks and lack of rust.
« Reply #8 on: December 10, 2019, 07:30:23 AM »
Looks like brazing to me
« Reply #9 on: December 11, 2019, 07:25:59 PM »
I think you are correct. I see no sign of heat penetration on the inside of the pan. Like one would expect with welding.
« Last Edit: December 11, 2019, 07:27:17 PM by ddaa99 »
Offline Lee Bowen
« Reply #10 on: December 11, 2019, 07:52:43 PM »
Would brazing generate enough heat to produce said marks?
With only one inside photo and one close-up outside shot  and a fairly long distance outside shot to go on, it is hard to identify the method with which they attached the legs. The outside photo shows white lines away from the actual attachment area, maybe residue from preparation for attachment, leading to my last post. Brazing was one of my first thoughts after actual welding (whether stick, mig, tig, or other, but the picture looks like someone mixed up a two-part chemical and smeared it on the skillet and then pressed the leg into the mass and let it cure.
Really brings out the redneck skill factor. :crazy:
« Last Edit: April 19, 2021, 12:20:41 AM by Cheryl Watson »
« Reply #11 on: December 11, 2019, 09:12:06 PM »
That stuff works, I've seen it fix motorcycles engines on trails.
Offline Lee Bowen
« Reply #12 on: December 12, 2019, 07:44:00 PM »
I used it one time to patch a hole in an exhaust pipe on my '67 Chevy pick-up truck, lasted several years.
