Author Topic: NG to LP  (Read 1318 times)
Offline Josiah Koval
NG to LP
« on: May 12, 2014, 09:46:20 PM »
Hi. Just picked up a 712 double burner and was wanting to convert to propane. What parts do I need to change and where would I find them. I have zero conversion experience. I have the PDF for the restoration and found it invaluable. Thank you all!!! (I do have the grates, they are being cleaned)
« Last Edit: May 12, 2014, 09:46:52 PM by jaykay1310 »
Re: NG to LP
« Reply #1 on: May 12, 2014, 10:05:56 PM »
See if this one helps at all... until someone else stops by... :)
Glad to see you stopped by!  (JK).... ;D
http://www.wagnerandgriswold.org/Attachments/CR1335723483.pdf
Re: NG to LP
« Reply #2 on: May 12, 2014, 10:13:26 PM »
« Last Edit: May 12, 2014, 10:35:10 PM by lillyc »
Offline John Knapp
  • I BUY 2 MUCH IRON
Re: NG to LP
« Reply #3 on: May 13, 2014, 08:01:42 AM »
I have used propane on the burners without changing the orifice and have had no trouble.  I do think it will be difficult to find a smaller orifice for the propane.  All I did was to turn the valve to about 3/4 the way on.
Re: NG to LP
« Reply #4 on: May 13, 2014, 08:57:57 AM »
Some of these stoves were made with an adjustable orifice. Can you show a close up of the valve, where it goes through the round air intake vent?
« Last Edit: May 13, 2014, 08:59:29 AM by Fryerman »
