Author Topic: Best sources for inexpensive lye  (Read 4140 times)
Offline Jeff McGrady
« on: February 02, 2017, 11:19:04 AM »
[size=12]I noted the Sticky for places to purchase lye, and appreciated the links in that post.
However, I wondered if anyone has discovered better sources to obtain sodium hydroxide?
Tractor Supply wants $14.99 for 2 pounds, and in looking on eBay I found the shipping costs a bit restrictive on some auctions.
I am hoping to set up my first lye bath in a 20 gallon resealable plastic tub, so would like to purchase at least 4-5 pounds of lye....maybe twice that much to have a second round, on-hand, though I don't wish to purchase 'in-bulk.'
The best price I have found in my short time researching/comparing is at Bulk Apothecary:
Sodium Hydroxide (LYE)
Size:      8 lb ($2.11 / lb) - $16.92 (+ $14.68 ship'g)
If anyone knows of a better source, and is willing to share, I'd appreciate it!    ;)
Thanks![/size]
« Last Edit: February 02, 2017, 11:20:30 AM by Flex68 »
« Last Edit: February 02, 2017, 01:02:25 PM by lillyc »
Re: Best sources for inexpensive lye
« Reply #2 on: February 02, 2017, 06:18:48 PM »
I have purchased it from my local Dollar store and from Big Lots, What I get is Drain cleaner which lists the sole ingredient as Sodium Hydroxide crystals, I paid $3.00 for 2 lb containers at Big Lots, I have used other crystalized and liquid drain cleaners that list lye as the sole ingredient.
Some of the drain cleaners have aluminum flakes listed as an ingredient, I avoid those.
« Last Edit: February 02, 2017, 06:21:35 PM by sewingstuff01 »
« Reply #3 on: February 03, 2017, 05:25:57 AM »
[size=12]Thank you both!
$3 for 2 pounds beats anything I had found, thus far....now if I can find a nearby Big Lots that carries the same thing yours does, I should be in bidness   8-)[/size]
Offline Lewis Downey
  • Lover of biscuits and molasses!
« Reply #4 on: February 04, 2017, 05:06:24 PM »
Idealtruevalue is in the sticky (I think) and their price per pound is a little higher than a couple of places mentioned in this thread. Their shipping cost can be pretty good if you buy in quantity. I usually buy 40 or 50 pounds of Rooto from idealtruevalue.com per order. The Rooto itself has been $2.22/lb from  for a while. The overall cost per pound varies based on the shipping. Shipping prices change at quantities of 10.  The table below does not include the cost of the lye ($2.22/lb). It only shows an example of how the shipping charge changes.
Feb 2017
lbs of lyeshipping charge to NC
10 lbs$10.99
11 lbs$12.99
20 lbs$12.99
21 lbs$14.99
30 lbs$14.99
31 lbs$16.99
40 lbs$16.99
41 lbs$18.99
50 lbs$18.99
51 lbs$21.99
Shipping 50 pounds to Raleigh NC adds an extra $0.38/lb on top of the cost of the lye - not too bad. The $2.22/lb price may not be the lowest, but combined with shipping it is a decent price.
« Last Edit: February 04, 2017, 05:07:00 PM by Lewisland »
« Reply #5 on: February 06, 2017, 03:34:37 PM »
[size=12]Thanks, Lewis![/size]
« Reply #6 on: February 12, 2017, 11:20:40 AM »
[size=12]I actually decided to go with Duda Energy LLC's 2 lb containers of Red Hot Devil Lye, 99+% Purity, Food Chemical Codex, High Grade Caustic Soda Beads, Micropearl Form.
The reason I chose to do so was when I attempted to order "2" of Bulk Apothecary's 8 pound sizes of sodium hydroxide, the shipping more than doubled from only a single 8 pound purchase. (?)
Duda Energy LLC had 'breakover' price reductions at quantities of 2, 6, 12, and 18, so I ordered 6 of the 2 lb. containers at $5.95 each plus $14.68 shipping.
Equated to less than $3.70 per pound, shipped to my door.
They also offered 50lb resealable buckets for a better price--- as well as palletized options that would have reduced pricing even further--- if anyone needed to order in bulk.[/size]
