Author Topic: EvapoRust Black Line Prevention  (Read 5053 times)
« on: April 22, 2020, 08:59:15 AM »
An EvapoRust trick. Those of you that have tried to take the rust off a big object that you can't completely submerge in the liquid have likely learned that a black line that is essentially impossible to remove, will form where the liquid meets the air. I've devised many methods to make sure I can completely submerge something, but I had a brainstorm when cleaning the old German hex waffle iron.
All I needed to do is to prevent the air from getting into contact with the iron and liquid at the contact. Something waterproof might work. So I smeared Vaseline (Petroleum Jelly) on the handles. Then made sure the liquid hit the handles on the jelly. Worked perfectly. No black line and a nice clean finish.
Pictures to show it in progress.
I did put Archimedes to work too, the pictures tell the story.
First pic, you can see the smeared on Vaseline.  Covers enough area to be sure the liquid/air line is protected.
Second, waffle iron in a 5 gallon EvapoRust can, but the level is below the Vaseline.
Third, Archimedes at work, filled a ziplock bag with water, put it in the can and displaced the EvapoRust high enough to hit the Vaseline.
Fourth, doing the other end of the iron handle.  I just had it hanging from a rack to hold it at the right level in the bucket.
« Last Edit: April 22, 2020, 09:07:46 AM by tomnn2000 »
Re: EvapoRust Black Line Prevention
« Reply #1 on: April 22, 2020, 09:10:08 AM »
Here's the old waffle iron after cleaning.
What looks like a line in the overall outside picture on the handle is actually a bump in the casting itself.  Look at both the inside and outside of the handles and you will not see any evidence of the awful black line.
I picked Vaseline because I had some, it doesn't stink like wheel bearing grease, and it washes off easily.  Pretty much anything that is sticky and waterproof would work.
« Last Edit: April 22, 2020, 09:13:27 AM by tomnn2000 »
« Reply #2 on: April 22, 2020, 11:36:46 AM »
Great tip Tom. Thanks for posting that. I've been moving towards a couple of applications for Evaporust. Preplanning looks like the key to success with it.
« Reply #3 on: April 23, 2020, 07:34:20 AM »
Here's a picture of the pan that taught me about the black line seven years ago.  Tried just flipping it a bit in hopes the evaporust would remove it.  Nope.  Now has two permanent lines on it.  Arrows point to them.
« Reply #4 on: April 23, 2020, 09:29:30 AM »
Does the Evaporust "etch" the iron?
« Reply #5 on: April 23, 2020, 10:13:15 AM »
Yes. At the liquid/air interface.
« Reply #6 on: April 23, 2020, 12:01:40 PM »
EvapoRust is a great product, you just need to be aware of it's quirks.  Vinegar will do the same thing if your aren't careful.
« Reply #7 on: April 23, 2020, 08:56:35 PM »
He's probably proud of you for paying attention in physics class  :)
Good work... you did a great job on that iron and it looks beautiful.
« Reply #8 on: April 23, 2020, 10:11:30 PM »
I knew about the vinegar and always kept a close eye on it. [smiley=shocked.gif]
« Reply #9 on: April 26, 2020, 08:28:41 AM »
Thank you Tom and Sandy thanks for the laugh!
