Author Topic: Help? What is this and Help/advice in cleaning it?  (Read 5560 times)
NJKane
« on: April 13, 2005, 03:54:33 PM »
Hello I found this at our local thrift store and purchased it since I thought it to be very unusual. (or at least I hope it is) I don't know the metal or if I can use Electrolysis to clean it but when brillo'd it comes up a shiny metal w/ lots of black (carbon? ) residue washing off.
Does anyone know what this is used for ? and how would it be used? and with help cleaning?
Thanks in advance.
Liz who is enjoying the beautiful sunny Jersey!
NJKane
Re: Help? What is this and Help/advice in cleaning
« Reply #1 on: April 13, 2005, 03:55:14 PM »
Oh yeah any idea as of the age?? Thanks again.. here is another shot
NJKane
« Reply #2 on: April 13, 2005, 03:55:41 PM »
last one..
« Reply #3 on: April 13, 2005, 04:15:31 PM »
Liz, I believe that is a pizzelle maker.  Here's a link that talks about them.  It may be aluminum.  See if a magnet will stick to it or not.
http://fantes.com/pizzelle.htm
« Reply #4 on: April 13, 2005, 04:43:18 PM »
Roger is correct....this is a pizelle iron.  These are up for auction fairly often.  I am almost positive these are aluminum.
NJKane
« Reply #5 on: April 13, 2005, 08:08:55 PM »
Thanks to both for your quick reply's and helpful link. I think I will try making these sometime soon. As Always.... WAGS fellow members get AAA+++ for always trying to help w/ any reasonable heck even sometimes off the beaten path question.
I sincerely appreciate it! ( SMILES*)
Liz
« Reply #6 on: April 14, 2005, 01:59:57 AM »
So Liz, is it aluminum?
NJKane
« Reply #7 on: April 14, 2005, 07:38:39 AM »
Yes Its aluminum. I had to locate a Magnet. I did look up the link on the above reply. Good Information. I will try cleaning it with the aluminum method listed on the side panel, also I saw some other entries when I did a search on cleaning aluminum.
I wanted to find out more about the maker of this item. BACCELLIERI BROS. MFG. CO. PHILA. PA ?? Any one know approx how old this is?
Thanks! Have a great day!
Carol
« Reply #8 on: April 14, 2005, 05:03:09 PM »
Liz, I followed Tom N's instructions for cleaning vintage aluminum and it turned out GREAT!  I thought he said to use 2 Tbsp. per gallon, then someone else says per quart.  I sort of winged it.  Boiled it for about 1/2 hour at a low simmer and I can't tell you how much stain just disappeared after I hit it afterward with SOS on the inside.  I did have to put in a tad of elbow grease with the SOS tho (not much, not much at all).  He knows tons about aluminum.  I wrote him an IM to thank him for the instructions but he may be away on vacation.  Looks like a pretty unit !!
« Reply #9 on: April 14, 2005, 08:49:35 PM »
One of my other favorites to collect.  The pizzelle (pronounced  pitt sell) is the italian version of scandinavian krumkake.  (The french/belgian version is a gaufrette)  A thin wafer/cookie.  The Pizzelle has a little more flour in it and is thicker.  It traditionally has an anise flavor.  I would guess this dates from the 1930's, maybe a little later.  They switched to wooden handles later.  They tend to be cast iron if much earlier.  A lot of manufacturers were in the Philadelphia area.  My favorite irons are made by Vitantonio from Ohio.
I don't think I would spend much time cleaning this up.  It's pretty decent.  The cream of tatar won't touch carbon, it handles stains and discoloration and is the last step I use.  If I really want to clean this I would see if it would fit in my self cleaning oven.  If not, I would heat the piece with a blowtorch and see if I could easily remove the handles, then run it through the self claning oven.  Then finish with cream of tatar with a steel wool polish.
Or you could use walnut shells and a sandblaster.  But I'd really not bother.
Carol, the SOS works great, but it is real coarse and will scratch aluminum leaving marks.  If I want to scrub I use a clear nylon scrubbing pad.  Then polish with 0000 steel wool - this won't leave noticeable scratches.  You onlly see the scratches with SOS if it is polished.
tom
« Last Edit: April 14, 2005, 08:53:38 PM by tomnn2000 »
« Reply #10 on: April 15, 2005, 12:25:45 AM »
Tom, is your last name pronounced "Nitt sell" by any chance?
« Reply #11 on: April 15, 2005, 01:19:19 AM »
Not quite, it's night sell.  And I'm not thin either.   [smiley=crazy.gif]
NJKane
« Reply #12 on: April 15, 2005, 06:52:07 AM »
Thanks Tom, Marty and Carol! Have a great weekend TGIF.. on my way to work ...
NJKane
« Reply #13 on: April 15, 2005, 04:14:36 PM »
Any idea as to the approx Year this one item was made? I found the name of the foundry in the link to the right but couldn't turn up any other information on the web?
« Reply #14 on: April 15, 2005, 10:07:39 PM »
I would guess in the 1930's
