Author Topic: Wagner #3 W/ heat ring?  (Read 3745 times)
« on: December 29, 2008, 11:42:37 PM »
I picked up a couple of Wagner #3's at an auction the other day. After a closer look, the one, a 3B looks to have a raised area around the outer edge similar to a favorite #3 w/ H R that I have. I will have to wait til it's out of the tank to get some pics for ya'll. I know there is some controversy about if Wagner ever making a #3 with a heat ring. Maybe this is one. Or have these been seen before?
Re: Wagner #3 W/ heat ring?
« Reply #1 on: December 29, 2008, 11:48:02 PM »
Chuck, the talk is, there ain't a number 3 with a heat ring, so you might really have something here. ;) I think I got that right.  :-/
« Reply #2 on: December 29, 2008, 11:51:04 PM »
It's not a real distinct H R like you see on a Gris, but it is definitley a raised area around the circumference of the pan.
« Reply #3 on: December 31, 2008, 07:15:11 PM »
Finally got this one done. Let me know what you think. Is it a heast ring or not. It has been worn down quite a bit but it is there. Looks alot like a favorite that I found on ebay, just that the heat ring is not worn as bad as mine.  http://cgi.ebay.com/Favorite-Piqua-Ware-Fry-Pan-Skillet-Kitchen-Ware-3A_W0QQitemZ150316423500QQihZ005QQcategoryZ976QQssPageNameZWDVWQQrdZ1QQcmdZViewItem The 3 I have, has a slightly upturned handle. It doesn't stick straight out. It angles up about 1/2" from the edge of the pan. IMHO this is a heat ring but I'll welcome debate on it.
« Last Edit: December 31, 2008, 07:15:42 PM by crogers561 »
« Reply #4 on: December 31, 2008, 07:52:13 PM »
Chuck,
  Could you post a picture of the side profile. Most Wagners had that outset heat ring, and straight sloping sides.
  I dunno if that's a good a good description of what I mean, but I hope you know what I meant... :-/
 More pictures always help.
Jeff_Paden
« Reply #5 on: December 31, 2008, 07:54:27 PM »
Doesn't look like a heat ring to me  :-? Mine looks like that too...
« Reply #6 on: December 31, 2008, 08:00:03 PM »
How's this?
« Reply #7 on: December 31, 2008, 08:00:22 PM »
and another
« Reply #8 on: December 31, 2008, 08:01:28 PM »
Ya like that little dohicky I have to hold the pan on it's side? It's called a Wife. Comes in pretty handy sometimes.  ;D ;D
« Reply #9 on: December 31, 2008, 08:03:50 PM »
Outer heat ring = a raised area around the circumfrence of the bottom of the pan. Maybe not websters definition, but pretty close.  ;D
« Reply #10 on: December 31, 2008, 08:06:24 PM »
The Favorite #3 on ebay has a heat ring, just not as worn as this one.
« Last Edit: December 31, 2008, 08:06:52 PM by crogers561 »
Offline Mike Bohannon
« Reply #11 on: December 31, 2008, 08:30:25 PM »
Chuck, I have one of those dohickies too but mine doesn't hold iron very well.  I will agree they do come in handy at times. :) :) Just glad my dohicky doesn't read the forum.   ;)Mike
« Reply #12 on: December 31, 2008, 10:26:31 PM »
Nah Chuck, this piece does not have a heat ring. A blind man should be able to tell if a piece has a heat ring or not. Some pieces do have a sort of raised wide area around the outside edge, but that is not to be confused with a heat ring, which is a definite raised strip or wall even. But this piece definitely does not have a heat ring.  :)
Charlee
« Reply #13 on: January 01, 2009, 10:16:46 AM »
*making a note that Chuck and Mike refer to their beloved as a "dohicky"* (filed under "useful information - bribery) ;D
My vote is not a heat ring, but perhaps a pattern was altered that DID have a heat ring...I can see what you mean...the outside edge of the pan is raised slightly, but not sharply enough to be a HR.
« Last Edit: January 01, 2009, 10:19:19 AM by Charlee »
Jeff_Paden
« Reply #14 on: January 01, 2009, 10:50:10 AM »
The Smiley Favorite 2's and 3's are very similar from what I recall.  Will check mine...
« Reply #15 on: January 01, 2009, 11:21:23 AM »
Hello Jeff, I am currently putting a set of them Smileys together. Have you got a picture of a 2? I don't recall seeing a 2. And have you got any extras laying around in your way? If so I'll let you know what I need. I got a 3 and a 1 at an auction on Tuesday.
I think Favorite was all over the place on them Smileys. By that, I mean wherever they could get a pattern, because they did use patterns from Wagner and Griswold. For instance, I got a 12 Smiley, its got an outside heat ring, and that is an old pattern, its got a Wagner Ghost on it and I believe "ERIE" also. And then I have a 13 Smiley and its got an inside heat ring and an all together different pattern, later, much refined, with an assist handle one piece and not open like Wagner.
Jeff_Paden
« Reply #16 on: January 01, 2009, 09:29:23 PM »
Here's the 2 but it wasn't a smiley as I thought...
« Last Edit: January 01, 2009, 09:37:11 PM by Jeff_Paden »
