Author Topic: Natural Gas vs. Propane Heat Value  (Read 1798 times)
« on: March 10, 2009, 08:55:12 AM »
I've attached a neat graphic I ran across that shows the relative heat value of propane vs. natural gas.  Many of the old stoves had an orifice sized for natural gas.  When you try to run propane through it it lets way too much through.  That's why you need to replace or resize, if an adjustable orifice, to use propane.
Here's the text that went with it.
"The additional hydrogen and carbon atoms in propane also mean that it produces more heat than natural gas from the same volume of gas burned at the same efficiency. Orifices for appliances burning propane are therefore smaller than orifices for natural gas burners (and also because propane is delivered under higher pressure, see above)."
« Last Edit: May 12, 2014, 10:31:55 PM by lillyc »
fatfutures
Re: Natural Gas vs. Propane Heat Value
« Reply #1 on: March 10, 2009, 09:24:16 AM »
Good stuff, Tom.
But, before anyone decides to switch out orifices... check 'em. Many (not all) older gas stoves had universal mixer pins. This allows you to adjust the orifice cap to obtain the proper size opening.... Smaller for propane, larger for natural gas.
« Reply #2 on: March 10, 2009, 11:50:33 AM »
WOW!! Thats more then double. Wonder what the cost per cf is between them. I will need to check my gas bill next time. I went all gas when I built this house because it was very low cost then.Now I think its higher then electricity... >:(
« Reply #3 on: March 10, 2009, 12:26:54 PM »
The Market price on Natural Gas reached about $13.00 back when gasoline and oil peaked (I think thats for 1000 cf, but not sure)  Today, its down under $4.00 on the Market.
maloney108
« Reply #4 on: March 11, 2009, 12:59:30 PM »
Hey Tom,
That goes to show you that it's true; a picture is worth a thousand words!  Thanks.
Here's the thousand word discussion we had last November:
http://www.griswoldandwagner.com/cgi-bin/yabb/YaBB.pl?num=1196263594/5#5
