Author Topic: Wagner Aluminum Round Roaster  (Read 5198 times)
« on: January 13, 2010, 03:15:25 PM »
Can someone tell me what number lid went with this roaster? Thank you.
Re: Wagner Aluminum Round Roaster
« Reply #1 on: January 13, 2010, 05:00:07 PM »
I can't say with a certainty but I would think the lid will have the same # as the bottom. FWIW, the RB has a # 7 with the same # on both pieces.
Offline Russ Weimer
  • Cast Iron, the other precious metal
« Reply #2 on: January 13, 2010, 05:21:19 PM »
I have a # 6 aluminum DO.  Both the top and bottom are marked 246.
RW
« Reply #3 on: January 13, 2010, 05:24:23 PM »
Same thing,  249.   Wagner kept most things simple like that.   It may have an "L" after it.   Meaning,  of course,  Lid.
Will 8-)
« Reply #4 on: January 13, 2010, 06:32:10 PM »
Thanks you all. Now who has a cheap one? ;D
« Last Edit: January 13, 2010, 06:32:59 PM by ddaa99 »
« Reply #5 on: January 13, 2010, 09:53:40 PM »
But DWAYNE, your questions WERE so easy.  ;D
Offline Russ Weimer
« Reply #6 on: January 14, 2010, 09:31:52 AM »
I have 2 #6 DO's  One lid is marked only 246 and the other is marked 246 m, the bottoms are marked the same - 246 and 246 m.  The "m" is located under the 246.
RW
« Last Edit: January 14, 2010, 09:33:00 AM by Russ_W »
« Reply #7 on: January 14, 2010, 05:26:27 PM »
RW
I have been told,  M for Magnalite
Will 8-)
« Reply #8 on: January 14, 2010, 09:04:13 PM »
I learn something new everyday.  What does the the P stand for that is found on some Magnalite?
« Reply #9 on: January 14, 2010, 11:32:59 PM »
We discussed this at a convention,  but my brain is failing to remember.   But we did figure it out.
Will 8-)
« Reply #10 on: January 30, 2010, 12:28:52 PM »
I am assuming that the Wagner Drip Drop Trivets are also for these #9 roasters??  I did not realize that they are that much larger than a Griswold #9.
« Reply #11 on: January 30, 2010, 01:00:22 PM »
Really????  WOW
« Reply #12 on: January 30, 2010, 01:18:47 PM »
Jeff, Is there a # on that trivet? Wagner made at least one roaster larger than the 249 and your trivet may be for the larger size.
« Reply #13 on: January 30, 2010, 01:37:07 PM »
Here you go Harry!
« Reply #14 on: January 30, 2010, 04:53:39 PM »
My 249 Aluminum Round Roaster is almost 9 1/2" inside diameter, does that help?
« Last Edit: January 30, 2010, 04:54:38 PM by ddaa99 »
« Reply #15 on: January 30, 2010, 05:39:04 PM »
Dwayne is where the sides and bottom of your round roaster meat rounded like most dutch oven or is it square??  The reason that I ask is that the 249 in the picture is 9 15/16" across at the widest point.  I think that it would fit if the sides met the bottom at more of a corner.
It will not fit in my #9 Griswold that is also 9 1/2" in diameter.  It fits in the oven but the feet don't touch the bottom.
« Reply #16 on: January 30, 2010, 09:58:00 PM »
It's rounded Jeff.  :-/
« Reply #17 on: January 31, 2010, 08:57:22 AM »
Well that really makes me wonder if either of them will fit??  I would bet that they probably do because that is why they were made but they sure didn't leave very much wiggle room??
