Author Topic: cone or wafle press ?  (Read 1702 times)
briguy101
« on: March 09, 2010, 10:32:37 AM »
Hi      I bought a round hinged press five and one half in.diam. With a floral design on the inside, it is stamped griswold mfg. co. pat.1880 the handles are stright round iron. I was hopeing someone could id. it for me       thanks brian
Re: cone or wafle press ?
« Reply #1 on: March 09, 2010, 10:50:21 AM »
Sounds like a Wafer Iron (Krumkake iron to a Norwegian!).  Does it look like the picture inside?
There are two styles of handles, one that is a rod that goes into lugs cast into the iron, the other is a rod rivetted to the iron. Essentially no difference in value.
The hinge style is called a button hinge.  I think you can see why.  There should be a base this fits onto.  The base is the most difficult item to find.
Complete, if I recall correctly, the wafer irons can sell from $150-$200, maybe a little more depending on condition.  The paddles alone usually are between $40 and $60.  Again maybe more depending on who is wanting one.
« Last Edit: March 09, 2010, 10:56:32 AM by tomnn2000 »
briguy101
« Reply #2 on: March 09, 2010, 08:26:12 PM »
Thanks Tom it is exactly like your photo. I am moving back to calif. and would like to save some weight ,I have ten skillets, an aluminum tea pot and a couple of pots with handels .  I would be happy to sell it all.                 Brian     951 440 3927
Offline Scott Sanders
« Reply #3 on: March 10, 2010, 01:11:18 AM »
Hi Brian.......Welcome to the WAGS Forum.  Do you or do you not have the base for the waffer irons???  You say you are moving back to California....from where???  If I'm not mistaking, isn't (951) Riverside, CA ???  Same as my prefix.  Maybe a cell #??  What kind and sizes of skillets??  What kind of pots???  You can post pictures if you want to.  You can only post one picture at a time unless you use something like Photobucket.
Welcome again,
Scott
