Author Topic: How to ship Griswold overseas??  (Read 6520 times)
5kidzrus
« on: March 28, 2010, 05:02:29 PM »
How to ship Griswold overseas?? We have movers coming to pack us up and I want to be able to tell them how I want the cast iron packed so to improve the chances of them arriving intact. I have about 15 pieces and I know that they will wrap in simple paper and layer one on top the other unless I make a stink.
I did read the shipping/ebay article and that helped - but I am hoping for advice more centered on sending multiple pans overseas. Thanks!
Offline Scott Sanders
Re: How to ship Griswold overseas??
« Reply #1 on: March 28, 2010, 09:05:40 PM »
Patty......Just make sure that your movers / packers know that cast iron is a fragile, brittle material, and should be packed as though it was glass.  If they pack it like glass, you shouldn't have any problems.  Just being nosey, but where is your iron going to???  :)
Scott
5kidzrus
« Reply #2 on: March 28, 2010, 09:12:08 PM »
Scott - Thank you for your considerate and speedy replies. We are moving to Germany, near the Czech. border. I guess my Griswold hunting days will be over while I am there ... unless Griswold's are stockpiles in Germany  ;D
I will tell the movers to pack the cast iron as the do the glass - great tip - THANK YOU!
Offline Ray Armstrong
« Reply #3 on: March 28, 2010, 11:00:38 PM »
Patty  Does that mean that we now have a European iron connection?
I'm a LYER!!!
5kidzrus
« Reply #4 on: March 28, 2010, 11:04:07 PM »
Yes! Of course! ... not sure what that means - but if I can get it for you and send it to you I will do it at cost. So does europe have great iron? I would love to get some Le Cruesets (sp?) but I have heard that the Dollar to Euro is weak.
« Reply #5 on: March 28, 2010, 11:28:19 PM »
Yes!
Hell if I know but I bet the dutch make one heck of an oven???
I'm a LYER!!!
5kidzrus
« Reply #6 on: March 28, 2010, 11:30:06 PM »
ROTFLOL!  ;D You all will have to add a new forum for Euro Cast Iron!
Offline Sam Roberts
  • Lodge what? !!!
« Reply #7 on: March 29, 2010, 01:14:00 AM »
Here is one line of European CI. I used to have a complete set of it, but gave it away to my best friend's daughter except for the retangular pan which I still use for corn bread. WMF CI makes excellent CI except for their skillets which are toooo heavy.
« Reply #8 on: March 29, 2010, 10:59:44 AM »
Patty this thread provides some info on packing to ensure safe arrival:
http://www.wag-society.org/Packing/Packing.htm
Don't forget that they usually load boxes of Fragile items with a front end loader and pack them in with a bulldozer  ;D
Offline Judith Holiday
« Reply #9 on: March 29, 2010, 11:00:14 AM »
Why not wrap the CI yourself? Buy a big roll of bubble wrap and some shipping tape and get it ready for packing yourself. Then you are sure.
"Freedom to differ is not limited to things that do not matter much." Justice Robert Jackson 1943
« Reply #10 on: March 29, 2010, 11:16:07 AM »
 That's what I would do. A good heavy layer around each individual piece. Then tape them together securely to fit into the box. Use a big enough box to allow at least 2" on all sides. Stuff the box tightly around the bundle, so that it can't possibly move around inside the box. Tape every seam on the box to give it it more strength.
« Reply #11 on: March 29, 2010, 11:29:07 AM »
If they all fit inside each other then you can use sections from a newspaper.  Just put the section so that the cast iron does not touch each other and you will be good.  I have shipped multiple piece before and done this with great results.
You could also use thin pieces of Styrofoam if you have that available.
« Reply #12 on: March 29, 2010, 12:10:30 PM »
I would do as Judith and Chris suggested.  What you spend on bubble wrap and good packaging will pay off in the long run.
5kidzrus
« Reply #13 on: March 29, 2010, 12:15:14 PM »
OK, thank you all for the advice! I especially like the idea of sheets of foam - I wonder if insulation foam board would work?
