Author Topic: Griswold Flat Bottom Kettle  (Read 7455 times)
Offline Roger Muse
« on: January 13, 2014, 12:40:05 PM »
I just got a late Christmas gift from a firend, a #7 Griswold Slant Logo "ERIE" Flat Bottom Kettle aka Bean Pot.  Unfortunately it is currently sans lid.
I have previously only had skillets in my collection.
This kettle has a little nipple on one side for a metal ring, but the ring is missing.  I will get some thick wire from the hardware store to make a replacement ring.
What purpose does this ring actually serve?
I first thought it might be used to help tip the kettle to pour out the contents, but the bail handle only folds down in the opposite direction.
Could it be for use with a long hook to help swing it out from over a campfire?
Forgive my ingnorance, but this has me confused, and I don't like guessing at somethings purpose.
Re: Griswold Flat Bottom Kettle
« Reply #1 on: January 13, 2014, 12:54:23 PM »
Hello Roger. Welcome to WAGS. On the kettle with the ring. If I understand your question, thats the way the kettle is supposed to work. The bale only folds down one way, and lets say you have your left hand on the bale, the bale actually locks in place at the top, and then when you lift the ring with your right hand, both hands are kept away from the hot kettle and its contents. So you can pour the contents out without being burned by the kettle. Hope that helps.  :)
Offline Roger Muse
« Reply #2 on: January 13, 2014, 01:24:04 PM »
Thanks for the quick response.
I always try to understand all the features on a piece of cookware.
I started my collection not to collect, but to actually cook with.
Now that I have a fairly complete set, I will try to work towards a complete "matching" set.
This Kettle is the first non-skillet Griswold in my collection.
I currently have:
#3 Large Logo Slant w Heat ring
#3 Small Logo early handle
#4 Small Logo grooved handle
#5 Small Logo late handle
#6 Small Logo late handle
#6 Nickel Plated Griswold's ERIE
#7 Best Made
#8 Large Logo Block EPU
#9 Large Logo Slant w heat ring
#10 Small Logo late handle
#10 High Dome Skillet lid, Large Logo
All told I have a grand total of $250.00 invested.
Offline Roger Muse
« Reply #3 on: January 22, 2014, 03:01:15 PM »
Another quick question concerning the Flat Bottom Kettles.
Do these usually have major grind marks around the bottom?
I am trying to determine if someone hit the bottom edge with a grinder after they owned it, or if it is just a normal part of the casting process.
It doesn't look like anyone took away any "meat" from the casting, so I guess it could be that the pour left a lip around the bottom that needed to be removed, but the grind is a little sloppy.
« Last Edit: January 22, 2014, 03:02:34 PM by Decoligny »
« Reply #4 on: January 22, 2014, 03:26:47 PM »
Hello Roger. I would have to see a picture of the area that you are talking about before I would venture a guess as to what it is. But grinding down at the bottom around a kettle or dutch oven to remove overflow from the pour in that area is not uncommon. But as I have said, a picture would help.  :)
Offline Roger Muse
« Reply #5 on: January 22, 2014, 04:34:22 PM »
Will try to take some pictures when I get home, will post tomorrow.
« Reply #6 on: January 22, 2014, 04:57:05 PM »
Yep,  that is how the later ones were cast.   http://www.ebay.com/itm/1906-1912-Griswold-Cast-Iron-8-Flat-Bottom-Kettle-Slant-ERIE-PA-p-n-811A-/171211064801?pt=LH_DefaultDomain_0&hash=item27dcf985e1
Offline Roger Muse
« Reply #7 on: January 23, 2014, 11:38:41 AM »
The #8 kettle shown on e-bay has a rounded bottom edge.
Mine has a sharp edge with what could probably be considered a heat ring.
« Last Edit: January 23, 2014, 11:47:20 AM by Decoligny »
