Author Topic: On the subject of Trivets  (Read 1242 times)
Offline Mark Zizzi
  • Doesn't like warped bottoms
« on: February 20, 2014, 09:05:12 PM »
I hope this isn't a dumb question, but I just received a beautiful WagnerWare #7 Round Roaster in the mail from a fellow WAGS member.  ;)
 It came with a trivet. I can see why that would be desirable as a collector, because it's part of the original set.
Other than that, I'm clueless about how or why they are used. I've read they're for keeping the meat off the bottom so it doesn't burn. Makes sense, but I recently made a pot roast without one, and it turned out perfect. So what's the real deal with DO trivets? Do you use one?.  Are there certain recipes that a trivet should be used? I really don't know what to do with it. Any insight greatly appreciated.   8-)
Offline Neal Birkett
Re: On the subject of Trivets
« Reply #1 on: February 20, 2014, 10:55:22 PM »
A trivet probably would not make much difference for a roast in a 350 oven with plenty of liquid in the bottom.
However, if the heat source was only from the bottom, ie, stovetop or fire/hearth, then it could help keep liquid circulating under the roast and inhibit burning.  Anything liquid would help keep temperature down with a trivet, but would not be as effective without.  Burning can occur in areas of restricted liquid circulation, like between a big chunk a meat and the bottom of a DO.  As what little liquid is present becomes steam and the pressure moves it out from under the roast, only the meat is left.  Continued steam now coming off the overheated meat keeps whatever liquid is around the roast from getting under it, and the meat browns then blackens.  There is nothing circulating to let heat escape other than thermal diffusion, which slows with reduced water presence.
Trivets may not PREVENT all burning if the heat source is too moderately too high, but it may be less.
Trivets probably do not do much to limit burning if the heat source is too intense, as whatever is in the liquid burns to the bottom of the DO.
My 2 cents.  Don't spend it all in one place.
Best Regards,
Neal
Offline Mark Zizzi
« Reply #2 on: February 21, 2014, 08:03:33 AM »
Thanks, Neal. I keep forgetting how these were used back then. Stove top or fire/hearth surely would make a difference. [smiley=scratchchin.gif]
