Author Topic: Two Burner Stove  (Read 4694 times)
Offline Scott Messenger
Two Burner Stove
« on: June 05, 2015, 08:52:11 AM »
Hello all, I've been on the Facebook page for a while (Scott Messenger) and decided to start an account over here for more research and information.
I've got my eye on a two burner stove that's in need of restoration, but appears complete with surface rust only. Ultimate goal for this piece is to be a user during my family camping trips.
I've got two questions:
1) Once cleaned of rust and crud, what's the proper way to protect the iron? Oil and heat seasoning?  Dare I say paint, like an enamel or something heat tolerant?
2) It seems straight forward to make the switch to propane. Are there any threads outlining this process? I did a quick search under "two burner" and "stove"  but didn't pull anything useful.
Re: Two Burner Stove
« Reply #1 on: June 05, 2015, 10:31:50 AM »
Howdy Scott, and welcome to the WAGS Forum!
Yes we have threads for sure!
Check out the Cleaning and Restoration Board..
Especially the Stickies at the Top of the Board.
http://www.griswoldandwagner.com/cgi-bin/yabb/YaBB.pl?num=1393982431
http://www.griswoldandwagner.com/cgi-bin/yabb/YaBB.pl?num=1245457429
Offline Robert Hynes
« Reply #2 on: June 05, 2015, 10:39:43 AM »
Nice cleanup on that Gris. Now I might have to buy the 2 burner stove i've been eyeballing.
« Reply #3 on: June 05, 2015, 11:15:55 AM »
Thank you Cheryl!! I knew this was the right place.
Looks like paint it is then. I didn't want to ruin the piece, but I've got too much German blood to own something that I don't use. LOL And the heat proof paint will make it easy to use and clean after each use.
« Reply #4 on: June 05, 2015, 11:33:03 AM »
Scott, a helpful hint when using the Forum search functions....
Click on the search TAB and do a more thorough search.
The search box in the upper right corner will only return posts within the last 30 days.  :)
(The next Forum upgrade will improve the quick search, but until then the Search Tab is the way to go... )
The Search Tab takes a bit of getting used to, just make sure you chose "All Posts" from the drop down, and check the box to display only one post per thread... :)
« Last Edit: June 05, 2015, 11:33:30 AM by lillyc »
Offline Jeff Parsons
« Reply #5 on: June 29, 2015, 03:42:20 PM »
Some of the Griswold's have adjustable valves (my 202 does). No disassembly, 2 turns with a 1/2" wrench close for propane, 2 turns open for natural gas. Beautiful design. Only problem with the apartment stoves like that is outdoors, the wind. (Make a foldable windscreen!)
